Intermittent A/C not working properly?
120,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
FIXXER25
I took it to a tech who vacuumed the system and recharged. The A/C now works fine while driving, however, when idling, both front fans go on and off intermittently, causing the A/C to blow hot every time the fans stop. The fans work in unison, either on or off. When the fans stop, the compressor clutch still continues to turn. I have checked all five relays that support the fans, and they are working. I don’t know what to do next.
Aug 2, 2023 at 11:49 PM
  • 55,845 POSTS
It sounds like the system is under or over charged, the high side pressure should be about 270 PSI when the outside air temperature is about 90 degrees. This video can help show you:
https://youtu.be/4EqdrBVb0sY
Can I ask if you had this problem before the A/C charge? Please go over these guides and get back to us.
Aug 3, 2023 at 6:46 AM
FIXXER25
Hi Ken, yes, the problem existed prior to the recharge. When I picked up the car yesterday, the A/C worked constantly while driving, and the fans (and A/C) would come on intermittently while idling. Now, the fans and A/C do not come on at all while idling. At 75F, the low side pressure is 60psi, and the high side pressure is 90psi, much lower than it should be. The compressor clutch spins constantly when the A/C is on. Appreciate any additional insight.
Aug 3, 2023 at 8:26 AM
  • 55,845 POSTS
Yep, you have a bad compressor, here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
and
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 4, 2023 at 4:02 AM
  • 55,845 POSTS
anything?
May 6, 2024 at 5:02 AM
