Vehicle has digital A/C control but not climate control since you don't set the actual temperature.
The A/C compressor has recently started turning off and blowing warm air. Turn off for a while and it will come back on (so far).
I checked the pressures (nice spot for high side port!) and they are a little low but no so much to cause compressor to turn off (35/210 at 85 ambient temperature). The air gap of compressor clutch seems to be about .40mm.
I'll check to make sure there is voltage at the clutch next and go from there. Seems this compressor has wear issue with clutch.
Any other advice for troubleshooting?
Thank you!
Thank you!
Jun 19, 2020 at 6:07 AM
