Intermittent "Service Rear Park Sensors" warning?
2015 RAM 2500
140,000 MILES • 6.4L • V8 • 4WD • AUTOMATIC
SUGARRAY40
  • 36 POSTS
For approximately 1-2 months I have been getting a warning from Service Rear Park sensors. This turns off the "beep" of the rear sensors. Then it will "ding" and start working. This seems to be more frequent off and on when it is cold and at times, I think it is related to taking off from a stop or park and when braking to a stop at a light or stop sign.
My local dealer (different from the previous ABS sensor) told me because my bumper was dented and the sensor was facing toward the midline of the truck, it was causing ghost readings between the 2 middle sensors. As such, they wanted me to put in a new bumper, which I declined at >$800 for the bumper and plastic top then new sensor housings and installation.
I "massaged" my bumper and to my eye the sensor is facing straight back now, but his has not improved the intermittent warning
My question: Could this be related to the main harness coming from the 42-pin connector in the driver's front wheel? My reasoning is that I've already had a problem from this harness with my ABS sensor and think "rubbing" will continue and compound over time.
If someone would share the wiring diagram, it would be greatly appreciated.
Feb 28, 2024 at 3:24 AM
  • 110,241 POSTS
There is a park assist module that controls the different sensors at the rear. The Module is in the vehicle behind the left kick panel.
If you look at pic 1, it shows the kick panel being removed. Pic 2 shows the module itself.
There are two connectors on the module. I attached a pin out of them below as well. This leads me to a question. Did they tell you which sensor was the problem? There are a few. Also, were any trouble codes provided?
See pics below. Note the colors of the connectors. C1 is black and C2 is gray.
Feb 28, 2024 at 11:46 AM
SUGARRAY40
  • 36 POSTS
The work order states stored code for sensor 11, cleared codes.
Which sensor is sensor 11?
Feb 29, 2024 at 4:08 AM
  • 110,241 POSTS
I attached a pic below showing sensor 11. It is on the driver's side.
Check the wiring to the sensor to see if there is any evidence of damage.
See pic below.
Feb 29, 2024 at 12:21 PM
SUGARRAY40
  • 36 POSTS
I took that harness off and there is no evidence of wear. I checked every line for continuity and had good continuity from each sensor connector back to the main 6 pin connector.
Feb 29, 2024 at 9:03 PM
SUGARRAY40
  • 36 POSTS
I have also rotated a new Bosch sensor from AutoZone through each sensor position without resolution.
Feb 29, 2024 at 9:04 PM
  • 110,241 POSTS
Check one of the working sensor connectors to determine if there is a 5v power reference. If there is, check connector 11.
For some reason I'm not finding the connector view at the sensor. That's why I'm suggesting doing it this way.
Mar 1, 2024 at 11:39 AM
SUGARRAY40
  • 36 POSTS
When I probe ground to power wire I get 4.1 volts at the 10 and 11 sensor harness. When I probe ground and signal wire I get 8.7 volts.
Mar 5, 2024 at 7:23 AM
  • 110,241 POSTS
The signal wire shouldn't have that much power. It sounds like there could be a short to power.
The 4.1v is a little on the low side, but I would think it would still start.
Let me know. Check to make sure the signal wire isn't damaged. Also, I am assuming this test was done with the engine off.
Mar 5, 2024 at 11:38 AM
SUGARRAY40
  • 36 POSTS
The engine was off but ignition on Run. I didn’t figure there’d be power without the key on Run.
Okay, I’ll open the loom and check the wire.
Mar 5, 2024 at 12:13 PM
SUGARRAY40
  • 36 POSTS
The wires all look good. I don’t think I need to take down the power and ground connections since it seemed to be just 1 sensor.
Mar 8, 2024 at 4:53 AM
SUGARRAY40
  • 36 POSTS
When I check resistance across the pins on the sensor I get these OHM readings: sensor 11 - signal to grey/orange 50.5 ohm, signal to grey/blue 174.2 ohm, grey/orange to grey/blue 131.7 ohm.
I then checked Bosch sensor from AutoZone with readings of 50.9, 184.1, 137.8 ohms.
Then checked sensor 9 and got 51, 184.2, 135.3 ohms.
I don’t know which wire is ground and which is power. In the attached pic the signal wire is the left pin, grey/blue middle, grey/orange right. I checked each sensor connector, and they are all oriented this way.
Not sure this helps, but it’s more information.
Mar 8, 2024 at 5:27 AM
SUGARRAY40
  • 36 POSTS
I then checked Bosch sensor from Autozone with readings of 50.9, 184.1, 137.8 ohms
I don’t know which wire is ground and which is power. In the attached pic the signal wire is the left pin, grey/blue middle, grey/orange right. I checked each sensor connector and they are all oriented this way.
Mar 8, 2024 at 8:36 AM
SUGARRAY40
  • 36 POSTS
I checked continuity from rear 6 pin connector for the sensor harness to the control module and had good continuity through all 6 lines.
Mar 8, 2024 at 8:37 AM
  • 110,241 POSTS
If you look below, I attached a pic of the connector and highlighted the sensor ground pin. Take a look and let me know if that helps.
See pic below.
Mar 8, 2024 at 12:12 PM
SUGARRAY40
  • 36 POSTS
It’s help confirm ground is the center pin.
I drove a 40-mile round trip this morning and no alert. It is raining here and it's 45 degrees. I’ll just have to see if all that fiddling made a difference, but I can’t find a concern with a sensor or the sensor harness. Wiring seems to be intact to the park sensor module too. If it picks up again, I guess, I’ll try to find someone I can swap modules with and see if it makes a difference.
Mar 8, 2024 at 11:01 PM
  • 110,241 POSTS
Actually, if you are able to find one you can use for testing, that would be a great idea. As far as the weather is concerned, it sounds like you live next door to me. LOL
Let me know if things change or continue working properly.
Mar 9, 2024 at 9:22 AM
SUGARRAY40
  • 36 POSTS
Thank you for all your help! And my brother has a 2500 I can swap out modules if I need too.
Mar 9, 2024 at 10:10 PM
SUGARRAY40
  • 36 POSTS
So, I didn’t even need to drive today. Service park sensors warning on as soon as I got in the truck after a remote start. It is 32-34 degrees with snow flurries.
Does the colder temperature point to a sensor or the module as being more likely?
Mar 10, 2024 at 5:01 AM
  • 110,241 POSTS
We have the same weather. LOL I'm not sure what is happening as far as the ECT. As far as the parking sensor is concerned, if you have access to another module, give it a try and see if that eliminates the problem.
Mar 10, 2024 at 1:13 PM
SUGARRAY40
  • 36 POSTS
So, I checked the sensor “clicking” today and sensor 11 was clicking but significantly less than the other 3. Also, I didn’t get the proximity alert from sensor 11 like the other 3 as well. So, I swapped out 11 for the Bosch sensor from AutoZone. Short drive to town, 3 miles, and no problems. We’ll see in the morning when it’s supposed to be 25-ish degrees.
Mar 10, 2024 at 1:35 PM
  • 110,241 POSTS
Sounds good. Let me know how things work out for you.
Mar 10, 2024 at 2:25 PM
SUGARRAY40
  • 36 POSTS
So far, 3 short trips today and no problems. 25 degrees this morning and 37 this evening.
Mar 11, 2024 at 9:36 AM
  • 110,241 POSTS
Thanks for the update. I'm glad to hear it is working. Hopefully, it will continue. LOL
Let me know how things go for you.
Mar 11, 2024 at 12:21 PM
SUGARRAY40
  • 36 POSTS
So, I have driven all week, in the rain. No problems. I guess it was just a bad sensor 11 the whole time.
Mar 15, 2024 at 11:02 AM
  • 110,241 POSTS
That is certainly possible. If it continues to work after a week, it should be fine. However, if anything changes, let me know and I'll try my best to help.
Take care of yourself.
Mar 15, 2024 at 12:11 PM
