Interior Lights Will not Turn Off
171,000 MILES • 4WD • AUTOMATIC
LARA ROSE
The interior lights in the vehicle have not turned on for several weeks. Now, they will not shut off. After starting the car, I had to drive home with the interior lights on and they will not turn off upon shutting off and exiting the vehicle.
Jul 17, 2016 at 2:17 PM
WRENCHTECH
  • 20,758 POSTS
I assume you have checked the dash light dimmer switch and the selector switch on the dome light.
If the switch's are not turned on you will need a professional scan tool to examine the body data to determine which door is open causing it. Then you can narrow down the area you need to troubleshoot.
Jul 17, 2016 at 10:00 PM
