Interior lights not working
125,700 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
INTOSILENCE1
  • 79 POSTS
My dome lights and mirror lights do not turn on neither when I open the doors or when I manually turn the switch on. However, all the lights on the dashboard including the gauges as well as the AC and radio controls turn on just fine. I checked both fuses that pertain to interior lights, one is located on the driver side of the dash inside the cabin. The other is located underneath the rear passenger seat. Both fuses seemed fine but I switched them out anyway and nothing happens still.
Mar 14, 2019 at 7:16 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Have you replaced the bulbs? Also, have you checked for power to the light sockets? First, confirm the bulbs are not bad. If they appear good, check for power to the light socket. You can use a test light or a volt meter to do this.
Here are a couple links that show how to use the tools I mentioned:
Let me know if any of this helps or if you have other questions.
Mar 16, 2019 at 9:39 AM
