Interior lights do not shut off from rear glass hatch
90,000 MILES • 4WD • AUTOMATIC
JORDAN_H10
Hello! When i just open and close the rear glass hatch to get stuff out of the back my interior lights never shut off. So I then have to go open and close a door for then to go off.
Is there a faulty sensor back there or a switch is on the wrong setting maybe?
Jun 5, 2019 at 3:20 AM
  • 55,616 POSTS
Either the switch at that particular door has gone bad or you have a BCM that is going out. To be sure here are the wiring diagrams and a guide so you can test the circuit and the BCM location with replacement instructions below:
Remove the knee bolster. Refer to Knee Bolster Replacement (Except Cadillac) , Knee Bolster Replacement (Cadillac)
1 Body Control Module
Remove the BCM cover.
Disconnect the electrical connectors.
Press on the tabs to release the body control module.
If a replacement module is installed, program the module. Refer to Control Module References .
Jun 6, 2019 at 7:34 AM
JORDAN_H10
Okay, I will start there, thanks Ken! You guys rock!
Jun 6, 2019 at 10:23 AM
  • 55,616 POSTS
Good to hear, please let me know.
Jun 7, 2019 at 3:49 AM
