Interior lights not turning off
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
KIMBERLY BLACK
Interior lights will not turn off. The manual does not say what fuse controls these lights.
Dec 19, 2017 at 10:15 AM
CARADIODOC
  • 34,414 POSTS
First be sure the dome light switch in the head light switch is turned off. Next, open each door, one at a time, and press the door switch. If you find one that makes the lights turn off, it needs to be reset. That is fairly easy to do, but there are two different designs depending on whether it is for a front or rear door.
Dec 19, 2017 at 10:49 AM
