Interior lighting
12,000 MILES • V8 • 2WD • AUTOMATIC
LUKE ALLEN2
Simple question, just don't have a way to find an answer.
Interior roof light comes on when I open door as normal, I was just wondering when I close the door, how do I turn the light on and off on command? I don't see a switch or lever anywhere.
Thanks
Jun 1, 2019 at 5:31 AM
DANNY L
  • 5,648 POSTS
Hello,I'm Danny.
If I remember correctly you just twist the headlight pull switch counter-clockwise.Let me know if that works or I'll look into it further.Hope this helps and thanks for using 2CarPros.
Danny-
Jun 1, 2019 at 11:29 AM
LUKE ALLEN2
It didn't work for me. The car is weathered so that mechanism could be broken. But I'm not sure. I know it still turns the headlights on normally when I pull it but turning it does nothing
Jun 3, 2019 at 9:13 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, it must be defective.You just twist the switch counter clockwise to turn the light on.Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 4, 2019 at 10:29 AM
