Blows cool to slightly warm at low rpm's then warm to hot at higher rpm's. Coolant level seems good.
Jan 2, 2018 at 4:36 PM
✓Experienced Mechanic
Good morning.
I would start by replacing the thermostat. verify the coolant level is correct. If the issue is still present you may have a clogged heater core. It will need to be flushed out of all debris.
Jan 2, 2018 at 7:16 PM
BRIAN SHANNON
MEMBER
Thanks Roy. I kind of thought, but wanted some corroboration from an expert. Appreciate it. Brian
Jan 2, 2018 at 10:45 PM
You are welcome Brian. Keep us updated with the result.
Jan 2, 2018 at 10:46 PM
