Need a picture of interior fuse panel?
213,000 MILES • 2.0L • 2WD • AUTOMATIC
JEN JARVIS
I have no cover and can't find one online.
Oct 19, 2022 at 1:31 AM
  • 110,251 POSTS
If you look below, pic 1 identifies the box and fuse orientation and identification numbers. Pics 2 and 3 are the fuse number, rating, and circuits protected.
I'm not sure what you are dealing with, but if it is a fuse-related issue, first confirm the fuse is good, if it is, it's important to determine if the fuse has power both to and from it. If there is no power, it's likely a bad fuse in the under-hood box.
Oct 19, 2022 at 11:56 AM
JEN JARVIS
Thank you so much. I could only find the diagram for 1998 or newer and we're not technically having any particular issues just don't have a cover on ours, so we couldn't tell which fuse went to what.
Oct 19, 2022 at 11:50 PM
  • 110,251 POSTS
Jen,
No problem whatsoever. I'm glad it helps.
Please feel free to come back anytime in the future if you have questions or need help with diagnostics or a repair. You are always welcome here.
Oct 20, 2022 at 11:25 AM
