fuse panel location large plug attached to the top of fuse box
35,000 MILES • 3.5L • 6 CYL • TURBO • 4WD • AUTOMATIC
CNLOOPER
  • 11 POSTS
What needs to be done with the large plug attached to the top of fuse box it's not getting a good connection and have to push it in and hold it and nothing is broke I need to know the fuse locations and what they run?
Mar 22, 2016 at 11:29 AM
HMAC300
  • 48,601 POSTS
Here is a guide to help you check the fuse with the fuse panel location and identification in the diagrams below.
Mar 23, 2016 at 12:16 AM
CNLOOPER
  • 11 POSTS
if a fuse has to be replaced how would you do it disconnect battery?
Mar 23, 2016 at 1:05 AM
HMAC300
  • 48,601 POSTS
you should be okay with the battery connected.
Mar 23, 2016 at 2:34 AM
