2017 Volkswagen Jetta Fuse Location
I attached the fuse box diagram and the function and amp rating of each fuse for you below.
These will not be the same. I need to ask a favor. We try to keep the threads specific to one topic and vehicle type, so it is more helpful to others. If you could, please start a new thread with the specifics you need and specific vehicle info. Here is a link to get it started:
I hope you understand why we request this.
Take care and I'll look for your new thread.
Suggested Repair
Install the 30A light-green fuse in interior fuse position 53, which calls for 30A. Leave position 52 empty if the car has no headlamp washers, since that slot calls for a 20A fuse, and leave unused position 54 empty. Match each fuse amp rating to the diagram before installing.
Conversation Summary
The owner of a 2017 Volkswagen Jetta TSI removed a fuse and could not remember its location, asking specifically about positions 53-55. Experts provided the fuse diagram and ratings: 53 uses a 30A light-green fuse, 54 is empty, and 55 uses a 15A light-blue fuse when equipped. The owner identified the removed fuse as 30A and noted that position 52 is a 20A headlamp-washer circuit not present on the car. The expert confirmed the 30A fuse belongs in position 53 and that an unequipped circuit likely needs no fuse.
