Interior Electrical
80,000 MILES
JONEILL
I have had no issues with my Jeep until last night, when i left work last night the battery was COMPLETELY dead, I was able to get it jump started w/o any unusual problems (started in a few minutes) however when i started it i noticed the the gauges "pegged out" and all of the warning lights came on. after a short time 3 -4 minutes they returned to normal, but the radio/clock had no power everything else seemed to be working. This morning when i turned the ignition to "on" the gauges again "pegged out" and warning lights came on, i also noticed that the lock for the rear get was trying to actuate, and the radio was still out. I checked multiple fuses including 21,33,18,13 all were visually good. I then cycled power by disconnecting the positive terminal from the battery for about 5 minutes, still the problem remains. Any ideas?
Apr 13, 2013 at 3:37 AM
check all fuses with a test light to verify.
sounds like low voltage at the battery causing havoc at the gauges.
start with battery voltage. should be 12.4 to 12.6
otherwise it may have a damaged bcm
Apr 13, 2013 at 4:03 AM
