interior dome light/cargo light
1995 CHEVROLET SILVERADO
165,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MATTWCR
interior dome light cargo light wont work.
Sep 5, 2016 at 12:50 PM
HMAC300
  • 48,601 POSTS
I assume the bulb has been checked and tried to go on manually and fuse has been checked. it may be a bad headlight switch and the dome defeat is causing it to not work. if all other courstesy lights work then it may be the problem or no power is going to it. so check orange wire to see if it's gets power from fuse and white wire to see if it grounds out to switch.
Sep 5, 2016 at 10:39 PM
