Interior accessories/no heater blower/no interior lights/no mirror adjustment
140,000 MILES
C.QUAM
Recently our truck has been having problems with the interior accessories. There is no power to the heater blower, radio, mirror adjustment, dome light, glove compartment light, etc.
The fuses and firewall connections are are good.
Does anyone have some suggestions of what may be wrong?
Thanks
Dec 30, 2016 at 12:40 AM
HMAC300
  • 48,601 POSTS
fuse number 2 under hood controls mirror and radio number 1 fuse controls blower 13 controls heater so check all those first. actually check all your fuses either under hood or inside truck
Dec 30, 2016 at 5:13 AM
C.QUAM
The fuses were the first thing we checked and they were all good. Just does not get power to the the fuse box.
Dec 31, 2016 at 3:37 AM
HMAC300
  • 48,601 POSTS
that is different from your question then check the fusible links in both pictures. it should be battery voltage on both sides if not they are burnt out. auto parts have them.
Dec 31, 2016 at 5:10 AM
C.QUAM
Thank you,
We will give it a try.
Dec 31, 2016 at 5:16 AM
  • 55,512 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
Jan 3, 2017 at 6:26 AM
C.QUAM
No we haven't gotten our problem fixed yet.
Jan 4, 2017 at 3:08 AM
HMAC300
  • 48,601 POSTS
have you checked fusible links yet? if you have then it may be a bad ignition switch not sending power to box.
Jan 4, 2017 at 4:00 AM
