Interested in buying: $1,000.00
1994 OLDSMOBILE BRAVADA
114,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
MISSCLARABOW
Runs great when its warmed up.
Issues: Stalls in low revs; Small kine electrical issues; Some quirks but overall great car
Other information:
114,000 original miles; clean title; second owner.
Regular maintenance, all records for life of vehicle.
AWD, 200-hp, 4.3-liter V-6, 4-speed auto with overdrive.
Registration and safety good till Feb 2019.
Great for camping, can go almost anywhere.
Does this look like a good buy or a possible lemon?
Aug 13, 2018 at 7:39 AM
  • 31,937 POSTS
This car may have hidden issues that can only be found by a mechanic doing a visual inspection. If there are no known problems that the seller is hiding, they should not have a problem letting you get an inspection done. This would not cost a lot and it is a good insurance policy against buying something cheap that will end up being a money pit.
Aug 14, 2018 at 12:26 PM
MISSCLARABOW
So, a car that tends to stall while idling (e.g. while at an intersection) there could be many reasons for such a thing?
Aug 14, 2018 at 12:50 PM
  • 31,937 POSTS
Probable fuel system related, or vacuum leak. If the engine starts to idle down and starts to shake often it is fuel starvation at idle or idle control is to low, if it will idle out of gear okay but falters when in drive, base idle may be set low or a vacuum leak is present.
Aug 14, 2018 at 4:46 PM
MISSCLARABOW
Very cool. Thanks for the assist. I love this place!
Aug 15, 2018 at 8:13 AM
DANNY L
  • 5,648 POSTS
You are welcome!
We are here to help.Thanks for using 2CarPros.
Danny-
Aug 16, 2018 at 11:48 AM
