Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Computer
Fuse
integration control unit relay
2000 TOYOTA CAMRY
225,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JOEESKIMO
MEMBER
what are the steps to remove the integration relay without having to remove the fuse box?
Dec 12, 2016 at 2:47 AM
Experienced Mechanic
It looks like the relay box needs to be removed, here are two diagrams that will help you located the relay and a guide to help you test it:
Images (Click to enlarge)
Mar 8, 2022 at 11:55 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
