I need to remove the intake manifold to have it replaced due to a cracked in it what tools do I need for it?
May 28, 2016 at 3:03 PM
HMAC300
✓Experienced Mechanic
normal hand tools sockets and wrenches. you may need fuel rail tools available at auto parts . all sockets and wrenches are metric 8mm-15mm depending on whether it is upper or lower manifold.
May 29, 2016 at 1:32 AM
IMDASHIZNT
MEMBER
1 POST
I have a 24valve dohc. It has 105,000.
I need to change my spark plug wires but have to take off the intake manifold to reach the back 3 wires. I need to know what the torque spec's are.
May 14, 2019 at 7:30 AM
(Merged)
BLMO
MEMBER
The tourqe is about 90 inch-pounds. I've been using about 8 foot-pounds, which is pretty close. Please let us know if you need anything else to get the problem fixed.
(Merged)
READY99
MEMBER
1 POST
My o6 TAURUS check engine lite came on so spark plugs,wires and dist cap was replace. A couple of weeks later car was running rough and no power. Notice pinholes on intake manifold assy. Use JB weld for a emergency fix that last for maybe 10 miles before new holes appear. Had new manifold intake install and last half a day before new pinholes appear again on new parts. With the pinholes on manifold assy is causing engine I believe is losing engine compression.What could be possible causing this problem?
May 14, 2019 at 7:31 AM
(Merged)
Hi there,
Thank you for the donation,
I have never heard of this before, there are often problems with alloy castings and porosity, but not pin holes appearing like this, can you post any pics?
