Intake manifold runner control stuck closed
160,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
MWMIKEYY
The engine light came on. And the code reader reported the "intake manifold runner control" is stuck closed. My question is, do you think that a gas treatment will help me with this problem? the control valve is behind the manifold I cannot get to the control rods to see if they are functioning.
Feb 13, 2018 at 1:18 AM
WRENCHTECH
  • 20,760 POSTS
Sometimes it helps. Sometimes it makes it worse also. There is also the possibility that the linkage has come apart. I think you will have to access the controls and linkage.
Feb 13, 2018 at 5:05 AM
