Hi, my original engine intake gasket failed and trashed the engine at 120,000 miles. My fault was using a little antifreeze.
Picked up used engine and Chevrolet dealer replaced intake with old engine and installed it and ran like new again. Then about 50,000 miles later it started using antifreeze again
Then I replaced the intake gaskets with Fel-Pro Intake Gasket Part # MS90131-2 I was told they were the best to keep manifold from leaking again. Now about 60,000 miles later the same thing.
Runs great Last time I replaced them I checked with straight edge and looked okay. I didn't replace the intake bolts when I did it last and unsure if Chevrolet dealer did.
My question is on the gasket manufacturer, should the bolts be replaced every time, and should I get the intake machined to be safe?
Thanks! PHIL
Thanks! PHIL
Jan 2, 2022 at 12:42 PM
