What are the signs of bad injectors and or intake manifold?
170,000 MILES • 5.7L • V8 • 4WD • MANUAL
STEVEN GRIBBINS
  • 26 POSTS
What would cause the truck to just start up and run about half mile then shut off, wait a few minutes pump gas like heck until it fires up then it only runs half hardly? I already changed fuel pump.
Feb 24, 2024 at 8:17 PM
  • 110,245 POSTS
What you described can be caused by several things. When you say, "... then dir wait a few..." does the engine stall, and then is difficult to restart?
I ask because a failing crankshaft position can cause issues when the engine is warm. It can cause the engine to stall and then restart after it cools off.
On the other hand, if you have to hold the throttle to the floor to make it start, that tells me it is flooding. When you hold the pedal to the floor, it shuts down the injectors when cranking. Are you sure the fuel pressure is within specification and not too high?
Also, if you have a live data scanner, check the coolant temperature sensor signal before starting the engine for the day. It should be close to ambient temperature. Additionally, let me know what the short-term fuel trims are at idle, operating temperature, and the vehicle parked.
Do me a favor. Take a look through this link and let me know if it seems to mirror what you experienced:
Also, let me know if there is any dark gray or black smoke coming from the exhaust.
As far as an injector or intake issue is concerned, either of the two can cause a misfire. Further damage to the catalytic converter can occur if there are leaking injectors.
Feb 25, 2024 at 11:12 AM
STEVEN GRIBBINS
  • 26 POSTS
The converters are cut off and there were a few spots bad on one of the boards in the fuse box I fixed what I could but I'm wondering if the one to see bad isn't to the cam shaft position sensor.
Feb 25, 2024 at 11:38 AM
  • 110,245 POSTS
If it was related to a cam sensor, you would have a diagnostic trouble code to go by. When it stalls, how long does it take to restart? If it has a delayed restart, check for spark to the plugs when it won't start.
Here is a link that explains how:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If there is spark, try holding the throttle to the floor when cranking to see if it starts faster.
Feb 25, 2024 at 12:10 PM
STEVEN GRIBBINS
  • 26 POSTS
I apologize but I should've mentioned it from the beginnging but the number 4 cylinders had no compression.
Feb 25, 2024 at 9:16 PM
  • 110,245 POSTS
The cylinder issue would cause a misfire, but it shouldn't shut the engine down. How long does it take to restart after it shuts down? Also, have you had a chance to look through the crankshaft position sensor link I listed above? If so, does it mirror what you are experiencing?
Also, if you have 0 compression in cylinder 4, you should disconnect the injector. Otherwise, it will continue supplying fuel that isn't being burned. Check to make sure the engine oil isn't polluted with fuel.
joe
Feb 26, 2024 at 11:03 AM
STEVEN GRIBBINS
  • 26 POSTS
I got new valve springs so I can replace these. please watch video and if possible, please let me know what the issue is.
Mar 3, 2024 at 6:29 AM
  • 110,245 POSTS
Are you able to move the push rod (see pic below)? Also, no that is not normal. Either we have a bent/damaged pushrod or something is broken on the rocker arm. It's hard for me to see it.
If the pushrod is can be moved, inspect the valve to make sure it isn't stuck down.
See pic below.
Mar 3, 2024 at 8:43 AM
STEVEN GRIBBINS
  • 26 POSTS
The push rod can be moved and I'm going to blow air into the cylinder to see if valve moves because the valve spring is very tight.
Mar 3, 2024 at 10:10 AM
  • 110,245 POSTS
If the valve spring is collapsed and tight, it sounds like a bent valve. Let me know what you find.
Mar 3, 2024 at 1:05 PM
