Intake manifold
192,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ANDREWCONDA69
I changed my intake manifold gaskets. Upper and lower. There is rubber seals for the end walls on the lower. It aid to put RTV on the corners. I forgot and now my engine is together mostly. Will I have a leak issue now?
Apr 11, 2019 at 6:11 PM
Good morning,
Yes, you most likely will have a leak from that area. the sealer fills the gap between the intake gasket and the seal.
5. Apply sealer GM P/N 12346286 (Canadian P/N 10953472) or equivalent to the ends of the intake manifold seals.
6. Install the lower intake manifold seals.
Apr 11, 2019 at 7:19 PM
