intake backfire
220,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
CHRISANDKYNDRA KEEFE
turn it over it backfires every time even on compression stroke cylinder number one will not start. firing order is correct. It ran before I changed the intake what is wrong with my engine?
Feb 23, 2017 at 2:38 AM
STEVE W.
  • 15,420 POSTS
If you did not pull the distributor the fuel timing should be okay. If the plug firing order is correct I would double check the injector harness. I would also check the distributor cap for any flaws. Have seen brand new ones with cracks in the.
Feb 23, 2017 at 8:04 AM
