intake air temperature sensor/mass airflow sensor
25,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
KDMDAWG13
wanting to locate iat signal where. i can t locate the sensor connection. i believe my car has an integrated iat/maf sensor. those sensors have up to six wires and i am trying to locate the iat signal wire. please help. thanks kenny.
Dec 8, 2014 at 10:54 AM
HOMER1967
  • 875 POSTS
the iat signal wire will be the blue wire with the black stripe on it,depending on ambient temperature you would typically see about 2.5-3.0 volts with the key in the on position.do you have access to a scan tool to read actual temperature. on a stone cold engine the iat sensor and the ect sensor should be within a few degrees of each other.also check the black/orange wire for battery voltage,12.6 volts and the red/black wire and the brown wire should be grounds.the red wire in the connector is the maf out put wire which should have about 1.1-1.5 volts at idle.hope this helps you.
Dec 8, 2014 at 12:21 PM
