Instrument panel lights not lighting
2001 FORD RANGER
150,000 MILES
TAMMY LAVALLE
Instrument panel will not light. Changed fused under hood (#33) and it worked for a few hours. Not working again and cannot figure out why.
Jun 17, 2018 at 9:11 PM
  • 110,244 POSTS
Hi Tammy and thanks for using 2CarPros.com.
The first thing I need to know is if the new fuse has blown, too. If it has, it seems there is a short. Take a look at this link. It discusses what happens and how to check.
If you found that the fuse has blown again, power to the interior lights comes from the headlight switch itself. I would start there and check to see if there are any damaged wires or one that could be shorting. The switch itself could be bad too.
I hope this helps. Let me know if you have other questions.
Jun 18, 2018 at 1:41 PM
