Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Interior
Instrument Cluster
Replace/Remove
Instrument panel
2001 DODGE CARAVAN
190,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
MONICA TAYLOR
MEMBER
1 POST
Turn signal and hazards turn instrument panel off. Please help. This occurred when I replaced the ECM/PCM.
Aug 16, 2017 at 9:36 AM
STEVE W.
Experienced Mechanic
Did you program the replacement PCM? They are not a plug and play part and if not programmed correctly they can cause a lot of issues.
Aug 16, 2017 at 12:15 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
