Instrument lights dim
130,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
MECHANCHICK
The gauge lights (Speedometer, tachometer, temperature) on my daughter's vehicle listed above are very dim. It's very difficult to see how fast you're going at night even with the adjustment wheel turned all the way up to the brightest setting.
I found instructions on how to pull the instrument cluster to replace the bulbs but I can't locate info on what size bulb and how many I need. Anyone know the answer to this?
The lights for warning indicators seem to be fine.
Jan 31, 2021 at 11:44 PM
  • 110,248 POSTS
I believe I have the Phillips part number. Here it is. 161LLB2 You can cross-reference that part number to other manufacturers. However, I would remove one and compare it to the part I mentioned just to confirm.
Let me know if that helps or if you have other questions.
Take care and God bless,
Feb 1, 2021 at 9:29 AM
MECHANCHICK
Joe, thanks for your reply. Any idea how many I'll need?
Busy single mom here and I'd like to have the bulbs at the ready so I don't have to pull the cluster, check the bulbs, re-assemble, order the bulbs and pull the cluster again after they arrive.
Feb 2, 2021 at 12:26 AM
  • 110,248 POSTS
Honestly, I went through three schematics of the instrument cluster and no show how many bulbs there are. What I would suggest is to first remove the bulbs and confirm the part number I gave you is correct. That is what my manual shows, but anything is possible.
Feb 2, 2021 at 6:35 AM
MECHANCHICK
Joe, thanks so much! It'll be my weekend project. :)
Feb 2, 2021 at 6:36 AM
  • 110,248 POSTS
You are very welcome. Please let me know if I can help and how things turn out for you.
Feb 2, 2021 at 6:38 AM
