instrument lights
10,025 MILES
RAY KAESER
instrument lights to dim to see. do not know how fast i am going. how do i correct this problem? Ray
Jun 1, 2017 at 6:54 AM
  • 55,748 POSTS
There will be an adjustment that is near the headlight switch like a thumb wheel. Turn that one way then the other to see if there is a change and get back to me
Best, Ken
Jun 5, 2017 at 4:51 AM
RAY KAESER
Ken that wheel adjustment works well at nite but does not work in the day time RAY
Jun 5, 2017 at 5:19 AM
  • 55,748 POSTS
Is it a LED screen or normal gauges?
Jun 6, 2017 at 3:57 AM
RAY KAESER
it is a LED screen, it gets dimmer and dimmer RAY
Jun 6, 2017 at 10:25 AM
  • 55,748 POSTS
What is happening is the voltage amplifier inside cluster is burning out. This means you will need a rebuild cluster.
https://youtu.be/_HEC44xENxw
Cheers, Ken
Jun 7, 2017 at 1:22 AM
RAY KAESER
Ken wher do I find this cluster ? RAY
Jun 12, 2017 at 6:42 AM
  • 55,748 POSTS
