instrument gauge LCD replacement
160,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JAMES COMBS
need to know if i replace LCD and ribbon on instrument gauge cluster if current mileage will still show up?
Apr 14, 2018 at 9:13 AM
STEVE W.
  • 15,418 POSTS
If you mean the driver information display, once replaced it will show the same information as before as that is stored in the instrument panels control section. If you replaced the entire panel then you would need to re-flash the unit to match your van.
Is it flashing or just out?
Apr 14, 2018 at 12:12 PM
