Instrument Cluster Pinout?
200,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
PAROXYSM
Hi guys,
I am in Australia and own a Toyota Aurion 2006. I am looking for a Pinout for the instrument cluster used. I selected Camry as there is no option for an Aurion vehicle. I ultimately want to find the Positive, Negative and Canbus High and Low to extract the canbus data to utilize in a racing simulator using the cluster as a standalone device.
Any help you could provide would be awesome!
Thanks in advance.
Mick
Mar 22, 2025 at 12:23 PM
  • 55,740 POSTS
Yo Mick! How are things down under? The Aurion is a Camry so no worries there m8. Here is the pinout for the instrument cluster. Check out the images (below). Let us know if you need anything else.
Mar 23, 2025 at 3:33 AM
PAROXYSM
G'day Ken you legend.
Thanks for your expedient reply. Unfortunately, that is not the cluster I have. The cluster I have has a 24-pin connector and a 16-pin connector.
I have attached a pic of the rear connectors.
Cheers bloke!
Mar 23, 2025 at 4:22 PM
  • 55,740 POSTS
Hmm, that is the only one they show, there must be a difference with the Aurion model. sorry m8.
Mar 25, 2025 at 3:44 AM
