Instrument cluster going haywire?
27,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
MATT MCELWAIN
I blew a fuse for the instrument cluster. I replaced the 5-amp fuse in the fuse panel under the dash of the driver side, after I put the fuse in the gauges work fine, but the all gauges are bouncing all over the place. is there a something that I need to do to calibrate them or reset them or what do I do to fix it?
Mar 27, 2023 at 12:51 PM
  • 110,251 POSTS
Based on your description, it sounds like something internally within the cluster has failed and is shorted. Because of the mileage and year, I would recommend returning it to a dealership. The repair should be under 100% warranty.
Mar 28, 2023 at 2:06 PM
