Instrument cluster doesn't register anything but check engine and speed. It's been sitting for 5 years. When I got it, I cleaned the fuel tank, replaced the fuel filter, air filters both inside and out. Then we did an oil change and spark plug change. Flushed the coolant and replaced the temperature sensor. Still no reading on the cluster and the fan doesn't engage unless the A/C is on. I'm about to replace the cluster and also the MAP sensor as when it's unplugged it's sluggish but runs. When plugged in it falls flat on its face. I'm curious if I'm missing anything that I can personally check before paying large shop fees. I've checked the fuses and the only one blown is the front aux 20 Amp fuse which I assume is the cigarette plug in the console. This is on the vehicle listed above.
Aug 13, 2023 at 12:07 PM
