Instrument cluster connector
100,000 MILES
CHRISPEL
I need the wiring diagram for the cluster connector.
Sep 12, 2020 at 5:43 AM
Good afternoon,
I attached the connector diagram for you to view. It identifies pins and there functions.
What is the current issue?
Sep 12, 2020 at 6:00 AM
CHRISPEL
The cluster is a direct swap into a 2002 Saturn S Series, but the SES light doesn't work. I was having a hard time finding this diagram, now I need the diagram for the 2002 Saturn SC2, so I can move the wires around to get it working. The turn signals and all the gauges work right now.
Sep 12, 2020 at 6:06 AM
Okay, I attached the Saturn below as well.
Sep 12, 2020 at 6:16 AM
CHRISPEL
Thank you very much. I have been looking for both diagrams for a year now. Looks like I need to move B6 to A7 on the Saturn connector. Fingers crossed the instrument cluster can understand what the BCM is programmed to send.
Sep 12, 2020 at 6:25 AM
You are welcome.
always glad to help.
Sep 12, 2020 at 6:32 AM
CHRISPEL
Moved the pin and the BCM would not let the car start. Guess I'm going to have to live without the SES light working.
Sep 12, 2020 at 7:14 AM
Okay, hopefully you do not have emissions inspection. That is required to work for inspection.
Sep 12, 2020 at 8:19 AM
