instrument cluster bezel
115,000 MILES
JDW80229
Trying to get to the heater/ac selector switch I need to get the outer bezel off for access. I can find no screws though it does seem to be very ridged at two points. A manual I bought on that years truck says to access two screws through the ashtray port, that port is far below the bottom of the bezel, I see no screws that would be the hold down. So the question is -
how do I get that darm bezel off without breaking it.
May 23, 2013 at 5:34 AM
  • 110,248 POSTS
I see no one has answered this, so I will try. If I recall, the bezel is held on with a valcrow type material. Try to gently pry the bezel away from the dash, Please be careful not to break anything. It has been some time since I worked on an 01.
Jun 4, 2013 at 3:19 AM
