instrument cluster not working properly
152,000 MILES • 4 CYL • 2WD • AUTOMATIC
TREEMAN002
when starting car all lights blink on dash, no gauge operation or tachometer, no speedometer, no cluster lights once warm it warms up starts to work normal but will set check light for fuel level sensor.
Nov 11, 2021 at 12:12 AM
  • 110,248 POSTS
When you say they blink, do you mean the flicker on and then turn off? Have you checked the connector to the rear of the instrument panel for loose or damaged wiring?
Also, there could be an issue with one of the two grounds from the IP. Check them as well.
I attached the wiring schematic below of the circuit. I highlighted the grounds. Confirm they are good, clean, tight, and not corroded.
Let me know what you find or if you have other questions. Also, if you find no issues, you should consider having the can-bus scanned for codes. CAN stands for controller area network. Basically, all the modules and computers are tied together via a few wires. This type of scan will provide codes regardless of the module storing them. Here is a quick video showing how it's done.
https://youtu.be/InIlnsjOVFA
See pics below. Note: I had to cut the schematics in half to make them readable. I did overlap them so you can follow from one to the next.
Nov 11, 2021 at 12:27 PM
TREEMAN002
Thank you for the info, I’ll will check ASAP and reply.
Nov 20, 2021 at 3:00 AM
TREEMAN002
The car is still at the repair shop where I bought it, they can’t find the problem, after a while it goes away. I bought the car as is, so I think I’m going to pick it up and check myself. I still may need help as I work on Toyota’s all my life. thanks
Nov 20, 2021 at 9:41 PM
  • 110,248 POSTS
I totally understand. You will end up with more in labor than the cost of the car. Regardless, I am here. I'll help as much as I can.
Take care and let me know what you plan to do.
Nov 21, 2021 at 9:56 AM
TREEMAN002
Thank you. most likely I have no choice and probably will need some help. talk with you soon.
Nov 21, 2021 at 10:57 AM
  • 110,248 POSTS
No problem. Let me know what I can do to help.
Nov 21, 2021 at 12:17 PM
