Cluster is flashing my dash lights and not showing my speed or how much gas is in the car and car hesitates to start.
Mar 4, 2022 at 6:05 PM
✓Experienced Mechanic
Is this limited to the lighting, or do you also have a problem with the fuel gauge and speedometer not working?
Also, have you checked the connectors in the rear of the cluster to make sure nothing is loose? If you look at the attached pic below, I highlighted the connector.
