Instrument cluster not working properly
2004 CHEVROLET IMPALA
109,000 MILES • 3.8L • V6 • TURBO • 2WD • AUTOMATIC
GERALD ALDRIDGE
Car listed above is an SS Indy edition made in Canada. all gauges are crazy except speedometer it works normal. Does it have the stepper motors?
Aug 20, 2021 at 7:19 AM
  • 110,244 POSTS
Some of the instrument clusters could have stepper motors. I don't have the specifics on the Canadian model, but I did find a technical service bulletin that may be of interest to you.
As far as the gauges, what exactly is happening? Have you checked all connections? I know there were some models that the IC would fail, but I'm not sure what exactly is happening for you.
I attached the TSB below. The primary complaint was noise, but it also included gauges not working correctly.
I hope this helps. Let me know if you have other questions.
Aug 20, 2021 at 2:41 PM
GERALD ALDRIDGE
Speedometer and fuel gauge work fine. Boost, temperature, oil don't start where they should so they are way off from being correct. The tachometer only works for a few minutes and then just drops and stays on zero.
Aug 21, 2021 at 1:00 PM
  • 110,244 POSTS
If they all started working like this at the same time, I don't think it's a stepper motor issue. I suspect the cluster itself is shorted internally. If the gauges are starting higher than they should, they have to be getting a signal (power).
I attached a general diagnostic test to confirm there is communication between the IC and related modules. Take a look through it and let me know if it is something you are comfortable doing.
Aug 21, 2021 at 3:32 PM
