Instrument cluster swap
250,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
YOUNGBUCK23
I have the instrument cluster from a 2003 Mazda Protege5. The car is an automatic with the speed/manual shift option. I was wondering if I can put this cluster in my 2002 Mazda Protege5. The clusters are a little different because the 2003 has a little screen that tells you what gear you're in, but I've already swapped the transmission from the 2003 into the 2002.
Jan 30, 2019 at 12:04 PM
  • 110,248 POSTS
Honestly, the new one may bolt in place, but it is different. When anything changes, it creates problems. I wouldn't recommend it. Is there something wrong with the one presently in the vehicle?
Feb 1, 2019 at 5:05 AM
