Will installing two air filters at intake of carburetor affect fuel consumption/performance?
98,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
TAIMUR91
Will two air filters (oil/wet and dry) installed in series at intake of carburetor of engine affect fuel consumption/performance etc?
Jul 24, 2021 at 8:04 AM
  • 110,246 POSTS
Anything that restricts airflow to the engine will cause the engine to run rich simply because there is less opportunity to draw air in. As a result, fuel economy will suffer and performance. Keep in mind, if the engine is constantly running rich, it can cause damage to the catalytic converter.
Is there a reason you want to have two air filters?
Jul 24, 2021 at 2:46 PM
TAIMUR91
Reason for installing two filters is dust and driving conditions. Can't we adjust the fuel ratio in carburetor through mixture screw, to ensure that engine is running neither too rich nor too lean?
Jul 24, 2021 at 5:17 PM
  • 110,246 POSTS
I guess that would be possible. However, does it have a carburetor or is it fuel injected? I don't show the Vitara for 1992. The only things shown are the Samurai and Sidekick.
That could simply be because of where you are located.
Jul 25, 2021 at 12:06 PM
TAIMUR91
It has carburetor. Branded also as Suzuki Sidekick, but has G16A (non-fuel injected) engine.
Jul 25, 2021 at 2:31 PM
  • 110,246 POSTS
When I look up a 2002 Sidekick, I get two options, TBI or MFI. See pic 1 below I even went back to a 1990 and it shows TBI.
Let me know if there is anything I can do to help.
Jul 25, 2021 at 2:48 PM
