When attaching the engine to transmission what is the torque or anything else that I need to do?
2,660,000 MILES • 5.4L • V8 • AUTOMATIC
HD2424
  • 190 POSTS
I’m installing a 5.3 rebuilt engine in my truck. When attaching the engine to transmission what is the torque or anything else that I need to do? I’ve seen from doing research some say there is supposed to be a certain gap between the engine and transmission at the bottom of transmission. Others say just torque them to 35-foot pounds.
My second question is the engine has been bored out 020. I know that’s not much. Do you think I’ll need a tune to adjust fuel and air because of it being bored?
The last question is, if I put a mild cam better than stock will I have to get it tuned for fuel and air?
Aug 24, 2022 at 12:39 PM
  • 55,627 POSTS
I would make sure the torque converter is installed completely so you don't damage the transmission front pump. Check out these two videos to help you so what I am talking about:
https://youtu.be/ZC7xHVMKLRw
This video is a complete install, but it has some great info on how to align the engine and transmission:
https://youtu.be/3vJAojsrfuU
Next, the .020 over will not affect anything.
Finally, I would leave the stock camshaft, an aftermarket cam will make it run worse if you don't have added compression to back it up. Let me know if you need more help.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Aug 25, 2022 at 5:54 AM
HD2424
  • 190 POSTS
Okay, thanks. I’ll keep stock cam and I’m in process of removing old engine and once I get it in, I’ll update here.
Thanks
Aug 25, 2022 at 8:41 AM
  • 55,627 POSTS
Good job, let me know.
Aug 26, 2022 at 5:26 AM
