Installing rear door glass
150,000 MILES
PRESTON LEE
How do you install new rear door glass?
Aug 16, 2017 at 8:44 AM
  • 55,746 POSTS
You must remove the door panel first and then the window regulator. On yours the rivets must be drilled out and it will be spring loaded so watch yourself.
Here are a few guides and a diagram to help you (below):
https://www.2carpros.com/articles/door-panel-removal
and
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Cheers, Ken
Aug 17, 2017 at 7:46 AM
