INSTALLED NEW STEREO NOW THE KEYLESS LOCK SYSTEM DONT WORK
68,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
MYERSTHEROCK
Replaced stock stereo with new Pioneer stereo . After much research and work , Running a new hot lead from the fuse box and using plug and play connections made just for this car. The car has a Bose speaker system and as I research it is common to hear a snap while turning channels or turning on (very loud) . Four hours later I have the stereo working fine but now the keyless entry system does not work, I think its due to the stock stereo and car had a alarm system . Hoping there is an easy fix for both problems , Hopefully just something I need to add ? Thanks for any help
Sep 17, 2014 at 9:49 PM
CADIEMAN
  • 3,544 POSTS
YOU NEED TO START WITH CHECKING ALL THE FUSES IN THE FUSE PANELS. TO CHECK TO SEE IF YOU BLEW ONE WHEN YOU INSTALLED THE RADIO. USE A TEST LIGHT TO CHECK FOR POWER ON BOTH SIDES OF THE FUSE WITH THE KEY ON. THEN COME BACK.
Sep 18, 2014 at 12:46 AM
