installed new stereo, clearance light fuse keeps blowing when lights are turned on
1984 NISSAN 300ZX
116,000 MILES
MUNCIE
Put an after market stereo in this car and now clearance light fuse keeps blowing when lights are turned on. i spliced into (not cut) two wires from original radio harness, one for ground and the other for 12volts with the key on.
Oct 11, 2013 at 11:20 AM
  • 110,244 POSTS
Does the fuse blow if the stereo is off?
Oct 11, 2013 at 12:11 PM
MUNCIE
It doesn't make a difference
Oct 11, 2013 at 12:24 PM
  • 110,244 POSTS
The only thing I can say is to recheck the wiring under the dash to make sure nothing was cut or damaged. That is the only place you worked.
Oct 11, 2013 at 12:41 PM
