Installation and removal of timing belt
COOKS935
Have found that this repair service is needed to be performed. Have already removed parts to access the engine to begin, but now need detailed instructions and illustrations to complete. Pretty positive that this is the issue with the car as it has been checked out by several different mechanics. It won't start and is backfiring while trying to turn over. Not sure if that is two hundred words or not
Sep 2, 2013 at 9:49 AM
  • 110,248 POSTS
What type of a repair are you referring to?
Sep 2, 2013 at 11:23 AM
  • 110,248 POSTS
I'm sorry, I just saw that you are dealing with a timing belt. Go to this page for diagrams of setting the timing belt. Also, you will have to remove the motor mount to remove the belt. Take a look.
https://www.2carpros.com/diagrams/daewoo/nubira/2002
Sep 2, 2013 at 11:26 AM
