Can the Lockup Solenoid B be replaced without removing the transmission?
250,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
BOOH97
I just want to know if Lockup Solenoid “B” can be replaced without taking out my transmission. I want to do it myself instead of taking it to a dealership and paying an arm and a leg.
Jul 10, 2023 at 11:09 PM
  • 55,694 POSTS
Yes, you can there are mounted on the outside of the transmission. Lucky you! Here are the instructions on how to replace the converter clutch lock up solenoids. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Jul 11, 2023 at 10:40 AM
BOOH97
Is there a DIY on how to get to it through the engine bay? It appears to be a tight squeeze. What else will I have to remove to access this solenoid?
Jul 15, 2023 at 4:56 AM
  • 55,694 POSTS
They don't show that, only the instructions I have included in the first post but if you take images of what the problem is I can help walk you through the repair.
Jul 16, 2023 at 2:57 AM
