Where is the input turbine speed sensor located?
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANTHONY602
I'm looking for the location of this sensor.
Nov 23, 2022 at 2:27 PM
  • 110,248 POSTS
To access the input speed sensor, you need to remove the battery and battery tray,
I attached the directions below for replacing the sensor. Take a look through them and let me know if you have questions.
Nov 23, 2022 at 3:18 PM
ANTHONY602
Thank you. Another question is, is the other sensor almost similar to the output speed sensor? I looked and there were two alike. These are the codes I'm trying to fix P0717-Input/Turbine Shaft Speed Sensor "A" Circuit No Signal any insight on it will be greatly appreciated!
Nov 23, 2022 at 3:49 PM
  • 110,248 POSTS
The code could indicate the sensor has failed, a wiring issue, or a control module issue.
Here is what I suggest. First, check the input speed sensor. The first 4 pics below are the directions for testing the sensor and wiring at the sensor. Do this first.
The next six are the procedures for testing the wiring, power supply, and ground.
As far as your question is concerned, yes, they are both located there and look alike. If you look at the very last pic below, I circled the two. ISS is the input speed sensor and OSS is the output speed sensor.
Let me know if this helps.
Nov 24, 2022 at 10:51 AM
ANTHONY602
Thank you for your reply. Having trouble finding info on this car online. This is the most I've gotten. Thank you
Nov 24, 2022 at 11:11 AM
ANTHONY602
Are you located in my area, you sound like a good mechanic?
Nov 24, 2022 at 11:12 AM
  • 110,248 POSTS
Anthony, I'm just old school. I don't like throwing parts at a vehicle only to find out it's not fixed. LOL, it goes way back to when my first automotive shop teacher said, "If it's not broken, don't fix it." That was 35 years ago, and I still hear him saying it. Technology has changed, but the same philosophy is still relevant in my mind. I guess I'm showing my age. I still have pride in my work and country.
I wish I was close, but chances are I'm not. I'm in Western PA.
As far as info on the vehicle, I have two different manuals specific to the vehicle. If you need anything, I should be able to get it for you, so don't worry about asking.
Take care and I hope you had a great Thanksgiving.
Nov 24, 2022 at 11:27 AM
