Input/turbine shaft speed sensor A circuit location?
328,111 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
DERRICKBENZ
Is this on the outside of transmission or inside? If outside, where is it located?
Aug 6, 2023 at 8:11 AM
  • 55,746 POSTS
Yes, both speed input sensors are inside the transmission. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 7, 2023 at 5:42 AM
