Code p0717, where is the Input speed sensor located?
2016 GMC ACADIA
110,000 MILES • 6 CYL • AUTOMATIC
MIKE MILINSKI
I have a p0717 code for the input speed sensor, but I don't understand the location.
Aug 6, 2023 at 3:28 AM
BORIS K
  • 836 POSTS
Your vehicle is fitted with the 6T75 6 speed automatic transmission.
To access the input speed sensor, you will need to drain the transmission fluid and remove the oil pan. Once the oil pan is removed, next you will need to remove the valve body. See image 4, item 18.
It is recommended to fit a new oil pan gasket(7N266), see image 3.
Once removed you will see the input and output speed sensors, see image 1 below.
I have also attached a wiring diagram to check the wiring from the speed sensor back to the TCM.
How to check wiring:
How to check fluid level for the 6T75 transmission:
https://youtu.be/HT8CKFp3KuY
Also:
Cheers, Boris
Aug 7, 2023 at 2:34 AM
