Input speed sensor location
2004 NISSAN MURANO
170,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
SOMEONEELSENOW
Car listed above is the SL model. I have been looking for days to find that darn Input Speed Sensor. Some been saying its near the starter, no luck. And I don't want to waste my time to have to lift it up, take things apart, and not find it. Please someone tell me or show me where that part is.
Dec 9, 2019 at 6:26 AM
AL514
  • 5,663 POSTS
It looks like you need to pull the rubber intake tube off, and the sensor is under the intake manifold attached to the transmission. Should be a grey connector, but be careful not to break it, it's in a place exposed to the elements. So they get brittle.
Dec 9, 2019 at 7:07 AM
SOMEONEELSENOW
Alright, I will have to check some day. Thank you for your response.
Dec 9, 2019 at 7:11 AM
AL514
  • 5,663 POSTS
If you still can't find it let us know.
Dec 9, 2019 at 8:12 AM
SOMEONEELSENOW
I think I found it but I doubt it's the input because shouldn't it be after the torque converter?
Dec 16, 2019 at 6:48 AM
SOMEONEELSENOW
Here is evidence:
Dec 16, 2019 at 6:53 AM
AL514
  • 5,663 POSTS
There seems to be 2 speed sensors on this model, one is inside the transmission and one outside. It should be a 2 wire sensor not 3.
Dec 16, 2019 at 9:42 PM
