I've found as high as 110 nm for inner and 60nm for outer which seems high compared to other sites. What should it be?
Jan 11, 2022 at 3:55 AM
SQM
✓Experienced Mechanic
Those specifications are correct.
The tie rod on the steering rack is 110 Nm (81 ft. lbs.)
Self-locking nut of the tie rod on the knuckle 60 Nm (44 ft. lbs.)
I have attached the instructions below.
Okay, the link you sent me shows 28 ft lbs at the knuckle vs 44 ft lbs that's why I questioned it.
Jan 11, 2022 at 4:59 AM
SQM
Where do you see the 28 ft lbs? The self-locking nut could be 60 or 70 Nm depending on the color.
Jan 11, 2022 at 5:07 AM
CHUCKDUARTE
MEMBER
Per the link you sent on the first message https://www.2carpros.com/articles/tie-rod-end-replacement it's the third to last picture which has 28ft lbs in the text. Although I did see in the attachments the 44/81 foot lbs for knuckle and inner. Just letting you know it causes confusion.
Jan 11, 2022 at 5:37 AM
SQM
Got it I see what happened. I included that guide just as a reference. As that is our standard tie rod end replacement procedure (different model).
The actual torque specifications are on the screen shot from all data that has your make and model.
